It is simply a bracket to hold the tail end of a breaker, it does not carry current or provide a fault path it is most likely stronger than the factory part.
I would have ordered the correct part but if I was in a panel and saw this I would not worry about it or recommend it be replaced.
Bob
Bob Badger Construction & Maintenance Electrician Massachusetts
