^^ That's what I was thinking. Then I went back and saw the SE cable in front of the waste water pipe and knew it had to be the electricins fault. The duplex receptacle for the sump pump is also odd. The electrician should've done it the right way first, this way he wouldn't have wasted time and money doing it the first time.
