Finally something up my alley. I see this all the time and if I'm there for an upgrade of equipment that requires me to pull wire I can't say it bothers me. It couldn't have been there to long as it is generally hard to get the plugs out after they have been in the weather awhile. I've drilled out many plugs, dug out the chico and pulled 1 wire out while pulling in several new wires many times. I generally use Duct Seal for wadding it works better than the fabric stuff. I never really thought about the listing use until I started reading this board [Linked Image]. One inspector told me that if he didn't see the sealing compound all over the outside of the sealing fitting I didn't seal it [Linked Image]
[This message has been edited by walrus (edited 09-28-2002).]
