I hear ya!!1
I guess I was looking at a standard off-the-shelf method of an economical code
approved device with some extra capacity. Some of the inherent problems of ground fault etc are important factors as well.
There are so many options one has to be selective to ones immediate process.
Although FPE is not a very good example because of some bad history in the US but the following URLS are interesting to review.
This URL is the Canadian arm of Schneider. They have a good write up on the subject as well.
http://www.schneider-electric.ca/www/en/products/ground/html/general.htm
Section 4 of the PDF file at the following URL is interesting from Powercon Corp of Maryland.
http://www.powerconcorp.com/docs/pcib-1031.pdf
Doug......et al
