Recently it was brought to my attention that under the NEC you must use either a wire nut, crimp or some other connecting device with the grounding wires in j-boxes. Someone mentioned that a gree wirenut with a hole in the end is a quick way to accomplish this, along with proper crimps. I was wondering if this requirement is in place in the CEC and if so could someone quote the code?
