There used to be an Article in the NEC tha was called "Under Plaster Extensions" and they took it out in the '93 edition. The wiring methods that you would be looking at will need to say suitable for embedding in plaster. AC, MC and MI cable are the cable wiring methods and of course you have numerous conduit wiring methods. Check Uses permitted,
