1 members (Scott35), 541 guests, and 38 robots.
#90801 12/11/04 08:43 PM
Hi,
I know that a drip loop has a 3 foot clearance from any window or door but what about a meterbase that is fed from a service lateral?
I do not think the code addresses that do they?
I know there is a height requirement usually 5-6-6" around here.
Thanks for any replies.
-regards
Greg
#90802 12/11/04 09:15 PM
I would have to say no. Look at 230-9(A). Unless your lateral is open conductors or a multiconductor cable without a overall outer jacket, It can be as close to the window as you like. A meter socket is accessible from the ground, so why would it matter if the conductors where 3' from a window, when I could go outside and touch them?
#90803 12/11/04 09:33 PM
Hi,
Thanks for the reply..I do not know what the feeder will be because the POCO installs the feeder from their xfmr to the meterbase using the 3" conduit I installed.
What is the requirement with a multiconductor cable underground?
-regards
Greg
#90804 12/11/04 09:56 PM
O
http://www.portlandgeneral.com/business/builders_and_dev/PDF/chapter5.pdf
http://www.portlandgeneral.com/business/builders_and_dev/PDF/chapter3.pdf
Meter clearances hear must apply to Electric service requirements from local power company.
Its a good idea to get a current ESR from your local power co.Has all the information,clearences and requirements
[This message has been edited by OreElect (edited 12-11-2004).]
