dana1028
Thanks you have the same opinion I do as far as 250.114, I only hope we are right.
406.3(D) tells you how you can create an ungrounded 3-prong receptacle....and 250.114 says you can't use it for anything you'd ever want to use it for.
Very well stated, yes that is exactly what I am having a hard time with, it makes no sense.
And as sparky pointed out, the average homeowner has no knowledge of this info and is not likely to spend $50 to buy the code book to know it.
If they did know it would that stop them?
I would think that 250.114 is there to require those items to have grounded cords, but they still could be plugged into outlets installed under 406.3(D).
IMO If this is not what the NEC intends, the NEC should not allows us to install 3 wire outlets on 2 wire feeds.
A label that says "no equipment ground" will do absolutely nothing, if the plug fits the outlet and the appliance operates the average person will use it.
Bob
[This message has been edited by iwire (edited 06-02-2003).]
