1 members (Scott35), 508 guests, and 35 robots.
#82144 10/18/02 08:25 PM
sparky Offline OP
Jack Frost cometh, and the poco's fragile infrastucture will once again spur genny sales here
The annual gala, spawns endless tranfere switch, interface, and KW-defying cajun manifestation's [Linked Image] , the latest here for your opinion etc......
An individual , with a Gen-tran & L14-20 twist lock wishes to 'make' into an older (homeline?) 4kw genny sporting a 120v 20a straight blade receptacle and a 240v 20A straight blade recptacle via respective male cord caps and a few flying splices, strictly temporary of course....
what say the BB???
#82145 10/21/02 09:13 PM
jes Offline
If the rig is like the one I have, the 120 volt duplex has one receptacle running off each winding (tab is broken on the line side terminals) and the neutrals are common...just like an Edison 3 wire. (There is 240 across the line side prongs of the receptacle). I have used it with two 120 v male plugs on short cords spliced in a weatheproof junction box to a single 4 conductor cord (line, line, neutral, equip grnd) running to a twistlock. Sounds like your situation. Would I do it for someone else?? NO WAY!
#82146 10/22/02 04:52 AM
sparky Offline OP
the man is going to update his genny, and has been 'read his rights' so to speak....
