1 members (Scott35), 565 guests, and 35 robots.
Cinner Offline OP
What is the DC current value that will give you the same amount of heat as 1.0 amp rms going through a 10 ohm resistor?
A).637 a
b) .707 a
c) 1.0 a
d) 1.41 a
[This message has been edited by Cinner (edited 04-05-2006).]
C--1 ampere
Actually it is (b).707
Roger
I agree with NJ. If you multiply the RMS by .707 again, it becomes PMS, which should be avoided.
Joe
Oooooops, I read the question again [Linked Image]
I also agree with NJ
Roger
Cinner Offline OP
Shouldn't the answer be:
1/0.707 = 1.41
1.41 x .637 = 0.9 amps.
Do you agree?
Cinner, the "rms" (which I somehow read as "AC" when I first read the question, who knows where my reading skills jaunted off to) already has the AC value equal to the DC value.
Roger
Cinner,
A few years ago, meters started coming out with the "True RMS" labels all over them. These meters give you a reading that is already the peak value X .707, or the RMS, or the heating value. If you had a less spiffy, average reading meter, you would take the displayed "average" value / .637, to get to peak, and then X .707 to get to your RMS value. Hope this helps.
Joe
But still avoid the PMS.
[This message has been edited by JoeTestingEngr (edited 04-05-2006).]
And the 10-ohm figure specified is one of these pieces of data thrown in to a question which is of no significance.
Since P = I^2 x R, 1 amp DC will give the same amount of heat as 1 amp RMS AC no matter what the resistance value (so long as it's the same in both cases, of course).
Answer C, 1 Amp.
