414
29
Greg, John,
How about with this new code stating that you can have a regular GFI outlet within 6 foot of the pool. What is to stop people from using a regular plug in a normal outside (GFI) protected recptacle?
Posts: 7,382 Likes: 7
In a short answer...nothing, nada, zilch.
Posts: 9,931 Likes: 34
... as long as the plumbing is set up so the 3' cord will reach
So in other words, you will not need the twist lock and you can use the regular outlet 6 feet away? Right?
Or, the orange extension cord, to a power strip, to a GP outlet (no GFI) in the garage.
It's been an interesting pool season so far.
John,
The best (worst) pool wiring job I seen was a motor (on an extension cord) plugged into a surge suppressor strip right next to the pool, where the pool crawler vacuum was also plugged in. Then it went to a 100 foot blue extension cord, that was plugged into a 100 foot orange cord, that ran down to the house, up over the roof of the house, which also plugged into a yellow cord that plugged into a receptacle in the back of the house. ( I don't even know if the receptacle was GFI. I told the lady whose kids were swimming in the pool that I though the install might have been a little dangerous. (to say the least) They got out of the pool right then.
