560
20
Hello folks, I am looking for some help. I have a customer with a range hood that has a bad switch. The switch is a 3 wire 4 position rotary switch. The positions are 1-load #1, 2-load #2, 3-load #1&2, 4- off. This switch is approx 1 inch square, about 3/8 thick. I thought it was going to be easy to replace until I tried to find one. The range hood manufacturer has gone under and there are few legible markings on the switch. I have exhausted my usual sources of these types of oddities. I can find it in pull chain but rotary seems to be more difficult. I was wondering if anyone has any info on a source for a switch like this.
Thanks Dave
Have you tried grainger, johnston supply?
it should be available it doesn't seem to be a complicated switch. maybe hard to find the very exact fit.
Posts: 7,382 Likes: 7
Leviton & Eagle are mfg that you could google. The days of having any local 'mom & pop' electrical supply & hardware stores are long gone around here (Big Boxes).
I would try Amazon, Barnett, McMaster-Carr, Grainger or MSC supply. If not available from one of them, then Marcone has quite a bit of that kind of stuff in their online catalogs. Appliance Clinic also has a good amount of parts like that available online as well. If all else fails, I think you can still find a basic Broan range hood for under $50.00 at the big box stores.
I have tried Leviton, P&S, Grainger, and a bunch of others with no luck. For the amount of effort already expended, I think KJay's suggestion of a new range hood is the best bet. This customer is an older widower and I was trying to keep things simple and inexpensive. Thanks all for your input Dave
I have an appliance supply place in Malden (Medford),ma that i use.
They pretty much have been able to accommodate most of my needs. I forget the exact name of it right now, i just know where they are and go there.
I' sure you must have a similar place up your way,stop the local 'Maytag guy',they should point you in the right direction.
