#185666 03/23/09 09:58 PM
Hi—
Found on the roof of a local starbux; it all sits on a TB supported by a piece of ½-inch EMT...
They look like a pair of 500W quartz-halogen fixtures.
How would you "bring this up to code"?
—busbar
[Linked Image from electrical-photos.com]
Admin #185670 03/23/09 10:41 PM
Just where is the violation?
OK, maybe there's a fill issue in the conduit body ... but using a Bell box would not change the support issue one bit.
The fixtures arefairlylightweight, and the length of the mast isn't very much.
Cheap? Schlock? Absolutely- but I think it meets code.
It's a violation of the support required by 314.23(F).
Good catch, Electure! So.... rigidis OK for this use, but not EMT.
Is there anough room inside the T to legally make up the splices?
Ghost307
I agree ghost307, that's a good question.
I have a sense of adventure, I just keep it leashed with common sense.
As long as you don't exceed the fill percentage of the fitting, you can make splices in them. I can't recall the Code section offhand though...
I have seen splices in T-fittings before, they seem to fit ok without too much drama.
Stupid should be painful.
mxslick #186143 04/21/09 06:56 PM
some conduit bodies are approved for a splice some are not and I don't know the differences.
mikesh #186150 04/22/09 01:57 AM
F
If they have the CU IN stamped inside the TB conduit body then yeah it can be used for splices otherwise no it can not be used for splices but I know some guys do used the oversied TB bodies for it and install the reduced bushing in there to make room for splices.
Merci,Marc
I've used the 'over size' method a few times.mainly for parking garage light retros'
