1 members (Scott35), 512 guests, and 32 robots.
#182542 12/01/08 12:48 PM
cgw Offline OP
Compression fittings vs set screw EMT fittings
Is there any advantage to set screw fittings over compression fittings?
Are set screw fittings significantly less time consuming?
cgw #182543 12/01/08 01:01 PM
Tightening one to four set screws is quicker then making a comp fitting 'wrench tight'; therefore yes, less time consuming installation.
Advantages? both are approved connectior/fittings; some 'say' the compression provide a 'better mechanical fault path'. Compression(aka 'raintite') have a purpose.
HotLine1 #182546 12/01/08 03:04 PM
Compression fittings give 360° grounding, and are better for EMI in sensitive (or electromagnetically noisy) environments.
Screw-set are significantly less time consuming, and just as good for most applications. A lot cheaper, too.
