1 members (Scott35), 507 guests, and 40 robots.
#173849 01/20/08 08:26 PM
drum Offline OP
I have been buying bundled RGB cable for some HDTV installs which has 6 mini coax and 2 cat5 wires inside. Most are done HDMI. It is handy but am thinking if I need a couple extra component cables RG6 quad sheild with RCA ends on it would work the same. Any opinions?
Yes it works. Component cable has an impedance of 75 ohms and so does RG6. I have crimped RCA's on a triplex of rg6 and it worked well. I try to keep them the same length - Im not sure it really makes any difference, But I do know there is a horizontal and vertical sync that is transmitted through the cables.
~Matt
I would rather beg for forgiveness then beg for permission.
Rarely is RGBHV used anymore (in consumer circles anyhow), except for computer monitors.
For consumer level Component video, sync is part of the Y signal (green plug). RGB has the sync on green.
All the Costco stores I've been to have their demo TVs connected with RG6 component cables. Looks like they use Snap N Seal RCA connectors or some other similar type of compression connector.
I guess you could use RCA to F adapters instead of RCA connectors.
rg6 does work, but be careful with the F to RCA connectors. Sometimes the added length makes it hard to fit behind a wall mounted plasma. Most companies make compression fittings in RCA for RG6.
They sell made up cables with one end "right angle" so they do fine in the close quarters behind a wall mounted TV. I doubt you could build a set for what they cost if your time is worth anything.
