1/8 hp max if using a breaker. 430.109(A) is general conditions while(B) is specific. When I get confused on an article, I will read the entire article. Then I will "remove" all the paragraphs that do not apply to my situation then read it again. In this case if you only read 430.109,430.109(A), and 430.109(B), you ought to be enlightened.
