176
11
greg, I think Alan Belson has the right idea. You have sunshine, use it. Alan--
They are usually wired on a 3 pole breaker. 1st pole uses phases A & B- 2nd pole uses phases B & C - 3rd pole uses phases C & A. Then it gets repeated this way. It keeps everything pretty balanced.
Bump! That a great point you have there! Thanks for bringing that up.
Luke Clarke Electrical Planner for TVA.
Solar is looking more attractive the more I look at it. They really only want a fan and light ... during the day Solar may be ok if that is all they are going to have, but you can bet, security lighting will be next, then how about a small air AC unit, so if you sell them on solar and then they come back with a bigger wish list your in trouble.
Suddenly, a simple 2-can bathroom out on hole 10 for us prostrate-challenged seniors turns into an air-conditioned 24 hour gourmet-restaurant with searchlights. Maitre d' "Has Sir actually booked a table? We are rather busy tonight. I may be able to fit you and your good lady in behind the paper towel dispenser in about half an hour."
Suddenly, a simple 2-can bathroom out on hole 10 for us prostrate-challenged seniors turns into an air-conditioned 24 hour gourmet-restaurant with searchlights. Maitre d' "Has Sir actually booked a table? We are rather busy tonight. I may be able to fit you and your good lady in behind the paper towel dispenser in about half an hour." Crazy is right, that is exactly what happend at out county course and the transportation center, they started out only wanting security lights, and it turned into a full a list of wants, the guy that wired them assumed only security lighting. If you really want to se how jobs can change from a simple request into a nightmare try dealing with the board on these gated communities, one member will want just the lights, then as soon as you start the job, another member, will come up with his idea, now the fun really starts, the whole board starts calling, in other contractors to look at the job you started, one member doesn't have any idea what the other is doing, then you find out, their rules din't allow the president of the board to approve you little lighting job, the guy looking to get the new vote for president is fighting with everyone. Crazy does not even describe, what a small light, in an out house can lead to, when your dealing with a gated community.
Posts: 984 Likes: 1
Then someone complains when they towel dispenser runs empty that they should have electric hand dryers...and the saga continues.
Ghost307
LK, Ghost .... are you trying to re-create "the never-ending story?"
"Solar is looking more attractive the more I look at it. They really only want a fan and light ... during the day"
How about skylights and a window?
LK, Ghost .... are you trying to re-create "the never-ending story?" Humm sound pretty tempting to recreate this story again I am sure it will anyway Merci , Marc
