1 members (Scott35), 406 guests, and 44 robots.
dale-electric.com from New York had many GE parts (switches, relays, plates, etc.) in a catolog that is not too old. Prices seemed reasonable.
Another draw back is you can't dim the lights with that system.
Dale is where I linked up at note 2
Originally Posted by gfretwell
Why are you so against them Jon?
I am wondering the same thing.
We still install GE commercial lighting control systems that use the standard RR-7 relays.
Usually they run a lighting program but we can install override switches and many times they will be a pilot version of the touch plate.
I thought of using RR-7s at this house but I was on a CMOS kick at the time and I liked the idea of being able to use 5v switching, current limited in the milliamp range.
Some of my issues are as follows.
Cant install dimmers.
Cant simply add a switch/leg
Cant easily find/replace switches
Must troubleshot TWO systems (HV and LV sides)
Relays here are generally in the attic.
Sometimes control voltage is DC.
I like simple things.
The only one that really jumps out to me is you don't want to be in an Arizona attic in the summertime ... makes sense to me.
Certainly running additional "switch loops" with bell wire seems easier that breaking into a wall to run 14/3 and you can still use a dimmer.
I think this would be easier to trouble shoot than a 3 way or 4 way loop.
