1 members (Scott35), 440 guests, and 11 robots.
Sean WB Offline OP
The chicago code will do me no good. Im in Texas, and I am under SBCCI .
I Ran 100' of sch 40 PVC this morning underground.*whew* I have got to get a trencher. fixing to go pull wire.
Thanks for the pointers.
I did not get as think so badly as you shocked I did.
Can anyone tell me what SBCCI stands for?, is this test harder than a regular Journeymans test. Does it allow one to work in several or all states?
It stands for Southern Building Code Congress International
heres a link www.sbcci.com
Donnie
Sean WB Offline OP
Well, I had the test this morning, along with about 15 guys. I was one of the last 5 to finish. The young guys(<20)were through with an hour to spare [Linked Image] ..
Anywho here is a question that was on the test That I kind sorta had to just take a stab:
[Linked Image] a 480 volt, 3 phase service feeds a disconnect that has only one motor on it fed by 250 kcmil, what size grounded conductor does the NEC require to this motor?
a.250 kcmil
b.1/0
c.2/0
d.does not require ground
anyway, whatcha think?????
[This message has been edited by Sean WB (edited 09-21-2002).]
Sean, Assuming that answer D should read "Does not require a grounded conductor" then that would be the best answer. If a motor doesn't need a neutral, you don't have to run one. But if it said "Does not require a ground" as you typed it, then the best answer (I think) is 250 kcmil.
Don't be concerned about those punks finishing early. They probably made a lot of careless errors and you probably just made sure you had the correct answer before you filled the bubble.
Back in school, I was so hard on myself that I had to not only get an A (or preferably, a 100%) but I also had to be the first one finished.
Boy, how things have changed since then!
Now I'm doing good to just pass!
-Virgil
5 Star Inspections
Member IAEI
Sean
I think the answer is D.
I don't think there is enough information to determine a groundING conductor size without knowing the type, and therefore rating, of the OCPD.
Correct?
Sean WB Offline OP
I am aware that three phase motors do not need a neutral. the last option was "ground" not "grounded conductor".
I remember coming across a FPN that said if a neutral is going to a 3 phase motor (presumably with some type of MCC equipment)that requires a neutral, It shall be same size as phase conductors.I will post my results of the test when I get them [Linked Image]
Sean WB Offline OP
Well Guys I received my results from the SBCCI Journeyman test today........,
I PASSED [Linked Image] !!!!
Thanks for the pointers Sparky66.
Well, What next?? hmmm........
Sean WB Offline OP
PS Thank you Mike Holt for your prep exams! (the free ones)!! If youre in here, Thank you
