Yes, I remember the switched MK plugs, although it's been a while since I've seen one.
As I recall, the extra layer of switch and connections appears as almost an insert between the plug base and top, making the whole thing about a quarter-inch deeper. Considering the widespread use of switched outlets, at least in domestic work, it's not surprising that switched plugs never really caught on.
I think MK did a version with both switch and a neon indicator light on the front as well.
