#13645 09/08/02 02:07 PM
has anyone used a GB circuit tracker, circuit breaker locator. Plug into receptacle and go to panel and run probe down and it is supposed to indicate which breaker is for the recp. i have been thinking of buying one so i did today and was wondering if any one else had used them and what they thought. also bought a klien conduit screwdriver/reamer something else i have wanted for a while.
#13646 09/08/02 06:20 PM
I got to use my circuit tracker last week for the first time , I was impressed with it
it tracked an outlet through a sub panel back to the main panel correctly
#13647 09/08/02 07:23 PM
i have one (it is made by GB also), it works great for residential, but i havn't had good luck with commercial.
#13648 09/08/02 08:31 PM
When I was in contracting, I had the Amprobe or Paser Tracers. They worked great however when I bought them back in '85 they were about $500 a piece. One was for dead circuits and one was for live circuits. I sold them both when I went out of busines. Now I have the GB small res. style of circuit tracers. It works well for me at my own house.
#13649 09/08/02 08:52 PM
i work in a factory hope it works out ok, iam going to try it out on some tommorrow, i will post back when i get off work.
#13650 09/08/02 09:04 PM
I own both the GB and the Pasar. The GB is not quite as accurate as the amprobe but it works ok. It's not fool-proof though so be careful of false readings. The Pasar is the best but you better get out your wallet.
#13651 09/09/02 08:17 AM
I've been looking at them also. Greenlee, AEMC, Amprobe, Ideal...I can't decide which one without hearing other's opinions.
I bought the Klein reamer, too. Maybe it's me but I don't think it works that great. Not enough clearance to get it into cut emt.
Don
#13652 09/09/02 09:42 PM
well i tried out the GB circuit tracker tonight and it worked good, i pluged it into several outlets through out the shop and i was able to locate the breaker it does pick up alot of interfearence up by the main breaker. as for the klien reamer i tried it on a pcs of conduit we had laying around and it didn't work as expected will take some getting used to or breaking in.
#13653 09/09/02 09:46 PM
jlh, the Klein conduit reamer does need some break-in time. Also if there is a burr on the conduit from the hacksaw it will hong up on it, don't give up on it though I use one regulary. The GB tracer works OK but sometimes does fool one about which breaker to shut off.
#13654 09/09/02 11:25 PM
Anonymous
Unregistered
jlhmaint,
How much was the GB unit? I got a cheapo Sperry for $30 just so I wouldn't be flipping so many breakers what with everyone having computers and all these days. I was really surprised it works as good as it says it would. You can also trace the circuit in the wall as long as it is hot.
