565
35
Where can I purchase a head lamp for working in unlit basements and attics.I am tired of biting on my small Mag flashlight. Chris
If you don't want the real thing, any well stocked electrical suply store or "big box" should have a cheap imitation of them. Also, try a camping supply catalog or store.
Peter
CT,Thanks for the suggestions.I never thought about the camping supply store. Chris
Lots of styles. Battery pack on the head band or on belt. Primary or rechargeable batteries. Lots of options. Some are very robust. http://www.caves.org/imo/lamps.htm
I have seen at target and walmart an actual head harness that uses your maglite for just that purpose. It is located in the camping section.
Cross country skiers also use something similar for skiing at nite. LL Bean's is a good place to get these. If they break, they replace them. Had good luck and very little hassles from them on replacing merchandise. If you are not an eyeglass wearer, there is also a unit that looks like plastic eyeglass frames with the lites on each ear piece. I wear glasses so I can't use that one. My stepson got one for xmas a couple of years ago from me and he uses it all the time.
[This message has been edited by Currently (edited 08-22-2002).]
Anonymous
Unregistered
Chris, Try a Police supply store. They carry all kinds of neat lighting stuff. I got a Surefire flashlight for attics and crawlspaces and several pen sized quartz lights at our local Police supply. The pen size lights are a lot lighter and smaller than a mag light. They take quadruple A cells, theyre bright enough to light up a J box in the attic and they last a LONG time. My next purchase will be their 2 stage headlamp with 7 led lamps, 2 for long life and all 7 for "high beams". They cost $35.00
Anonymous
Unregistered
Oh and by the way. Mag light makes a plastic mouthpiece for holding the light. No joke.
I purchased a Streamlight Septor headlamp about a month ago. This is an LED unit, light, 3 positions - 1, 3 or 7 LEDs. Uses 3 AAA batteries. I don't know how I lived without one!! Cost $35.00
REI.Com has a nice selection of headlamps. Some even have the external battery packs so you do not have much weight on your head.
SD It is best for a leader to be both feared and loved. But since this usually cannot be done, it is safer to be feared.
