0 members (), 433 guests, and 18 robots.
#117716 07/06/04 07:33 PM
im guessing its for cutting emt or flex or the like with a hacksaw when a bench or vise isnt close at hand....? whats my prize? or whats the penalty, never seen or heard of one before,just looks feasible!
#117717 07/06/04 07:56 PM
Some type of fuse puller, or a tool to install/remove the tension springs from 'jaws'????
Close but no cigar?????
#117718 07/06/04 08:23 PM
Looks like something out of an underground jointers kit may be!!!Very early Eddison
#117719 07/06/04 09:56 PM
OK, here's my guess-
Maybe it's a tie wire wrapper for knob-and-tube wiring; it looks like a porcelain knob would fit in the "U" portion. Then again, actually using this to do a complete tie-wire wrap may be a physical impossibility...
This one's really got my head a'scratchin'!
No wire bias here- I'm standing on neutral ground.
#117720 07/06/04 11:56 PM
I think Scott is messing with us and it is actually an old table leg...
#117721 07/07/04 01:55 AM
Its a torture device for homeowners that do their own electrical work and handymen. [Linked Image]
#117722 07/07/04 08:40 AM
sparkystudent is right.
Los Angeles used to allow up to 100' of aluminum flex to serve as an equipment grounding conductor if it was cut with one of these.
I haven't used it since the early '80s.
It doesn't work worth a darn... [Linked Image] [Linked Image] S
#117723 07/07/04 09:19 AM
I'll be darned. Never would have guessed that. And I've been using the Benfield Saw Box for over 20 years. . . [Linked Image from benfielddirect.com]
Were the two little hooks a way of sturdying the tool and flex while cutting?
Al Hildenbrand
#117724 07/07/04 12:42 PM
E57, I just typed in "adjustable nut driver" at www.ebay.com
There is one for sale right now. (I'm not gonna bid, just wanted to know what one looked like. The pic doesn't show it very well)
#117725 07/08/04 07:43 AM
Al,
See! You've already got one.
As far as I can tell, the little hooks are there just to make it harder to put the hacksaw in...S
