Electricians revenge
1 members (Scott35), 128 guests, and 12 robots.
#116837 04/29/04 06:52 AM
Note:
This is the answer to the question posed in https://www.electrical-contractor.net/ubb/Forum5/HTML/000521.html
AKA: "Wireway the Right Way"
Yes, it's the transformer mounting. We had to buy 6X6X1/4" square tube and
weld base plates on it. Then we hoisted the steel up into the wall and
welded the top to the structural steel above and anchored it to the floor.
Unistrut was welded to the steel to make the transformer support. The whole
operation was designed by us and approved by a structural engineer. Welding
was done in house by a certified welder. It turned out pretty clean!
Nick
[This message has been edited by electure (edited 04-29-2004).]
#116838 04/29/04 06:57 AM
I knew you HAD to have some kinda contraption going on there... Good Idea for whoever came up with it! [Linked Image]
Hella lot better than this...
originally from https://www.electrical-contractor.net/ubb/Forum4/HTML/000346.html
-Randy
[This message has been edited by Lostazhell (edited 04-30-2004).]
#116839 04/29/04 02:15 PM
WOW! Good eye Randy. You da man!
#116840 04/29/04 04:53 PM
Wow, was I off!
All the ones I've seen I always sorta assumed (there's that word) that the wall didn't have any additional bracing. [Linked Image]
You even have those verticle braces, they were just hidden to make it look all the better. Good job.
-John
#116841 04/29/04 06:16 PM
Randy, your picture is of what looks like a demo job in progress.
Where did you take it??
#116842 04/29/04 08:00 PM
Electure.... Its from another post..
I just linked it for comparisons sake.. https://www.electrical-contractor.net/ubb/Forum4/HTML/000346.html
-Randy
