2 members (gfretwell, Scott35),
534
29
Picture and info submitted by renosteinke: was on the roof of a restaraunt, replacing light bulbs, whan I came across this hazard. When the PoCo did their attachment, they failed to insulate their crimp connections. Of course, this did not prevent someone from mounting a light- atop the metal roof curb, less than a foot from 800 amps of heavenly transportation!. Click here for larger image Thanks John.
Reno, I thought they did this on purpose so that service technicians working on the roof would have a handy power source they could clip onto - both 120V and 240V. No ??
Seriously, I've seen this exact thing many times down here, usually from the ground when I'm not in a position to do anything about it.
Radar
not to mention shock risk, I can just imagine hoe easy it would be in a high wind one night, one of those uninsulated line crimps starts banging against the bare POCO neutral...
That used to be the norm around here actually, and it is very common to find a service with bare split bolts just floating... Had a roofer walk back into the service of the house behind me and blow a hole in his shirt... Had an actual PoCo employee arc out a service a few doors up from me.... Scary isn't it
Hey, Reno is that a big hole in the roof across the parking lot? LOL
and.....is that a Utility Co XFmr sitting on the sidewalk in front of the Salon next to Good Times?
SE, I went back and looked- and yes, it sure looks like one! It was kind of hard to be sure, what with several coats of paintes-over graffitti, and assorted merchandise piled against it (-:
I'm not sure "mounting" is the right word to describe the light, either -- It looks like it's floating 1/2" above the wall. Interesting conduit work there: EMT into a 90 into a coupling into a nipple into a whatever. I hate seeing junk like that.
not to mention shock risk, I can just imagine hoe easy it would be in a high wind one night, one of those uninsulated line crimps starts banging against the bare POCO neutral... more like a spectacular light show
Cliff
