1 members (Scott35), 414 guests, and 29 robots.
#101401 03/21/07 10:43 PM
... that all receptacles shall be GFCI
#101402 03/21/07 11:04 PM
Ewire, see NEC article 210.8 for all GFCI receptacle requirements. The 2005 NEC made this change. It calls for ALL commercial kitchen receptacles to be GFCI protected. For single and multi-family dwellings it's different. Just trying to help.
Good luck!
shocked Whoa! Mark20, is anyone still making receptacles with paper (actually, fiber) backers on the mounting screws? The Big "L" (you know who I mean) standardized on plastic some years ago. Varying temp and humidity caused too many problems with the fiber stuff. And, OK, once in a while a changeover mechanic forgot to shut off the backer feed when the strap (yoke) had a grounding clip attached, but QA usually caught that. I apologize for getting just a wee tadd bit off topic. smile
