Electure,
you are absolutely correct. When you would have use 2 kWh if you drove the car directly with electricity, you'll need at least twice that if you want to use hydrogen. And that is provided "they" manage to improve the efficiency of fuel cells! Unless the fuel cell is significantly cheaper than a battery, it will fail.
[This message has been edited by C-H (edited 01-09-2004).]
