Sparkync
The braces you are describing are usually located in the corners of the building. Try to relocate the devices further away from the corners if you can. Also in some of these older buildings you will find 'ballon' framing, which will save you a lot of effort. In the basement, go to the gable end of the house and look up at the framing. You may just see the 'balloon framing, or try pushing the snake up into the framing. If it is 'balloon' framing, you have got it made in the shade
Pierre
