Install a 3way switch. Feed the point; one traveler goes to the unit feed and the other traveler goes directly to the backside (output) of the detector. This gives you two choices: motion and always on. If you want a shut off switch make it a 2 gang box and put a plain single pole ahead of the 3 way. Make the output of the single pole feed the 3 way's point.
