Hi.
With regard to a residential setting:
What brand(s) of outdoor motion sensor light allow(s) for an additional wall switch to enable/disable the detector?
I know that many brands use a quick on-off-on or similar method to override the motion sensor, but the light will reset itself after x hours.
I would like to be able to occasionally completely disable the motion sensor, and manually operate the light.
Let's throw in another variable. What brands allow for a dusk-to-dawn sensor as well as a motion sensor, both of which can be manually disabled?
