Joe, the only problem with using the virtual drive method is they write CDs in a proprietary fiormat that another machine may not be able to read. You are better with using a burner program and making Joliet (usually called "data disk" by burners) files. "Music" CDs are yet another format (CDA)
I am guessing Trumpy's WMA files are not recognizerd by the burner when it tried to convert to CDA. I think most only take WAV or MP3s. WMAs may also have the copyright bit set.
He can probably make Joliet files but a CD player won't see them.
Winamp will let you make WAVs out of your WMAs and then you can burn a music CD but you need a lot of disk space.
