What's missing is the ACTUATOR ARM....the looped handle, designed to be snagged by a hook on the end of a pole. This is usually on the side of the box....what you see is simply a lever actuated indicator, so you can tell the position from a distance. (On some of these switches the actuator didn't move very far).
