0 members (), 392 guests, and 30 robots.
#98915 06/22/06 07:10 PM
Since the big issue of having raintight connector on conduit and EMT. What does that do for couplings? What if they are underground?
As Roseanna Danna said- "It just goes to show you it's always something."
George Little
#98916 06/23/06 12:26 AM
I thought it was "If it ain't one thing it's somethin else"
#98917 06/23/06 12:28 AM
Seriously, with raintight connections how is the condensation supposed to drain out???
#98918 06/23/06 01:07 AM
Never Mind [Linked Image]
George Little
#98919 06/23/06 02:00 AM
I think the whole "rain tight" thing is marketing hype. You still need to drill a hole to let the water out.
#98920 06/23/06 09:29 AM
Greg I think you are right about the hype with one exception, - If the connector or coupling is installed above a piece of gear that could be damaged or compromised by water entering around the fitting, then it makes sense to have a watertight fitting. As for something in the ground or something that needs to be drained anyway- who cares if it's rain tight. I used to think that compression connector/couplings were required in wet locations because they provided a better ground path than set screw connectors/couplings but I'm not so sure anymore with all the tolerances permitted.
George Little
