#95845 10/12/05 11:54 PM
cruzer Offline OP
question can you use more than one ground on a ground clamp on the water pipe,does the ground pipe have to be bonded.
#95846 10/13/05 05:30 AM
Any wire terminal has to be listed for use with more than one conductor if you want to use it that way.
I have not seen ground clamps listed for more than one conductor.
If you mean does a metal raceway enclosing a grounding electrode conductor need to be bonded the answer is yes it does need to be bonded at each end.
