170
8
i recently took an examination in texas and one of the questions on the test has me baffled. what is the maximum ampacity rating for a hermatic refigerant motor branch circuit against ground fault? no other specs were included. my choices were 25 30 35 40.any help greatly appreciated. thanks
I suspect there was something missing in the question and so the Smart A** is 40 since that is the largest option. Maybe they expected you to recall some information from another previous question??
George Little
Posts: 9,932 Likes: 34
Using "test taking" logic I would go for 35a since it is the only one that is divisible by 7. 440.22(A)"..."a protective device having a rating or setting not exceeding 175 <seven quarters> percent of the motor-compressor rated-load current..." I bet there was a 5hp motor in there somewhere. (20aFLA)
Originally posted by Gfretwell Using "test taking" logic I would go for 35a since it is the only one that is divisible by 7. 440.22(A)"..."a protective device having a rating or setting not exceeding 175 <seven quarters> percent of the motor-compressor rated-load current..." I bet there was a 5hp motor in there somewhere. (20aFLA) Would this be the same thing as 14 bits? [ [This message has been edited by jw electric (edited 09-13-2005).]
Mike
One quarter ($.25) equals two bits. Not so many years ago a gallon of gas was just under two bits of you would get four cents back from a quarter.
Mike
I sang "Shave & a haircut....two bits" to my son & he looked at me like I was the strangest thing in the world.
I may be old, but you're older jw. Gas was probably around 35 cents/gallon when I started driving.
Dave
Sorry I am not octal, I am hex based.
(A "bit" originally being 1/8th of a "piece of eight")
I guess we old computer guys never change.
Mike
CDS
Nicholson Ga
