164
12
1) Leave the FPN just where they are. Enforceable or not, they are a good bit of information, and ahving to "go look for them" would not help.
2) If there is a table, chart, diagram, figure, etc., put it with the text that references it, not several pages before or after the text that references it. Look at just about any other book, and you don't reference a figure or chart and then put that figure or chart several pages away.
3) Use "plain language" in the text. Say things plainly and simply. You do not get points for using $50 words when $3 words would work just as well.
Thanks Steve
Since you asked:
I would love to see Article 430 revised.
When looking at Figure 430.1, It would make sense if the motor feeders were part 1, the motor feeder short circuit protection was in part 2, motor disconnecting means in part 3, and so on and so on. Right now you have to go from part2, to part 5, then part 9, back to 4, then 2.
It doesn't make sense to me.
But you asked......
Dnk.........
FORM FOR PROPOSALS FOR 2008 NATIONAL ELECTRICAL CODE ®
Mail to: Secretary, Standards Council National Fire Protection Association 1 Batterymarch Park, P.O. Box 9101 Quincy, Massachusetts 02169-7471
Fax to: (617) 770-3500
FOR OFFICE USE ONLY Log # Date Rec’d
Notes: 1. All proposals must be received by 5:00 p.m. EST on Friday, November 4, 2005. Proposals received after 5:00 p.m. EST, Friday, November 4, 2005, will be returned to the submitter. 2. Type or print legibly in black ink. Limit each proposal to a SINGLE section. Use a separate copy for each proposal. 3. If supplementary material (photographs, diagrams, reports, etc.) is included, you may be required to submit sufficient copies for all members and alternates of the technical committee.
Please indicate in which format you wish to receive your ROP/ROC: o electronic o paper o download
Date Name Tel. No. :
Company
Street Address
Organization Represented (if any)
1. Section/Paragraph
2. Proposal Recommends (check one) o new text o revised text o deleted text
3. Proposal (include proposed new or revised wording or identify wording to be deleted). Note: Proposed text should be in a legislative format: i.e., use underscore to denote wording to be inserted (inserted wording) and strike-through to denote wording to be deleted (deleted wording).
4. Statement of Problem and Substantiation for Proposal. Note: State the problem that will be resolved by your recommendation; give the specific reason for your proposal and include copies of the tests, research papers, fire experience, etc. If more than 200 words, it may be abstracted for publication.
5. o This Proposal is original material. Note: Original material is considered to be the submitter’s own idea based on or as a result of his/her own experience, thought, or research and, to the best of his/her knowledge, is not copied from another source.
o This Proposal is not original material; its source (if known) is as follows:
If you need further information on the standards-making process, please contact the Standards Administration Department at (617) 984-7249. For technical assistance, please call NFPA at (617) 770-3000.
I hereby grant the NFPA all and full rights in copyright, in this proposal, and I understand that I acquire no rights in any publication of NFPA in which this proposal in this or another similar or analogous form is used.
Signature (required)
PLEASE USE SEPARATE FORM FOR EACH PROPOSAL
HCE727
Delaware County, PA, USA
