by Hutch - 05/13/24 04:23 PM
Electricians revenge
#90304 11/14/04 10:05 AM
What's wrong with using a three way switch (SPDT) for switching between the disposal and the dishwasher? I'm saving the cost of a circuit and breaker. Need code reference.
George Little
#90305 11/14/04 10:15 AM
Why use the switch?
How much do these units draw?
#90306 11/14/04 10:42 AM
Should have provided more details. You run a single circuit, probably 14/2 to a 3 way switch located above the kitchen counter for controling a duplex receptacle below the counter where you have the disposal and dishwasher plugged in. You run a 14/3 cable from the switch to the receptacle and break the tab off separating the two halves of the duplex. Now when you toggle the 3 way switch you will be providing power alternately- Switch up- disposal runs, switch down dishwasher runs. Saved the cost of a circuit and breaker.
George Little
#90307 11/14/04 10:43 AM
Bob
I believe George uses the switch as an electrical interlock. When the switch is up the disposer is on, and when down the dishwasher is powered.
I guess i need to type faster.
[This message has been edited by watthead (edited 11-14-2004).]
#90308 11/14/04 12:41 PM
I know and I do not know any code reason why you could not do this.
Also I asked why use the switch because if the GD draws 3 amps and the DW 13 amps one 20 amp circuit could be used as long as no other outlets where included on that circuit.
Bob
#90309 11/14/04 02:10 PM
Not sure if this is legal or not but we have something like this in the jail where I work.
The light switch for the room lights and the night lights is a three way. Up = room lights on night lights off. Down = room lights off night lights on.
At least with this method they will not forget to turn on the night lights.
#90310 11/14/04 04:31 PM
Another variation where George's setup has benefit is putting a small instant hotwater heater on the same circuit as a garbage disposal.
One outfit markets an air switch for the control of the disposal that does exactly the same thing that George's 3-way does.
But I have to wonder about the dishwasher purely from the manufacturer's perspective. Solid state controls are appearing on more and more dishwashers. A power interruption will re-initialize the control chips. The older mechanical clock would just pick up where it lost power.
Al Hildenbrand
#90311 11/14/04 05:09 PM
I don't know of any code violation, but it seems a poor design, IMO. I'd personally prefer a 20-amp circuit running to the dishwasher and disposer switch, leaving the dishwasher with unswitched power.
Dave
#90312 11/14/04 05:34 PM
I guess it would work fine that way.The question is why?With that set up,you can't run the disposal and dishwasher at the same time.I would run two circuits myself,a 12/3 would work nice.Better job that way I feel.A single 20 amp circuit would work too if a circuit needed to be saved.
[This message has been edited by andyp95 (edited 11-14-2004).]
#90313 11/14/04 09:56 PM
Not to be the bearer of bad news...
Is the DW supplied with a factory cordset??
If not, does the mfg instructions say that a cord/plug connection is allowed??
References to NEC Article 400 prohibiting cord from replacing permanent wiring methods.
