0 members (), 433 guests, and 18 robots.
#85415 07/02/03 07:01 AM
gserve Offline OP
In reference to 334.15(C) what is meant by "angles"? If I install a 4/O SER on the face or the studs in a straight line across the studs is this code compliant?
#85416 07/02/03 11:29 AM
DJF Offline
I believe that normally 90^ & 270^ = Perpendicular, 0^ & 180^ = Parallel so these are not included in "angles".
Any derivation from the above would be the angles that are being addressed.
#85417 07/02/03 12:49 PM
anything not parallel to the framing members is an 'angle.' See the NECH - there is a color graphic showing the intent of this section.
