1 members (Scott35), 528 guests, and 31 robots.
#8430 03/21/02 04:36 PM
Hello
I have two 120 volt / two speed motors. Each has a high and a low speed.
I am told that there is some sort of three way disconnect that disables the low and enables the high and vice a versa.
Is it as simple as a 3 way switch controlling one leg or the other ?
#8431 03/21/02 10:17 PM
if the motor has only 3 wires ,a common, hi & low. a 3 way switch would work fine if it can handle the load. just one thing though it want have a on or off. [Linked Image]ERWIN
