561
36
http://www.nfpa.org/PDF/DocProp.pdf?src=necdigest FORM FOR COMMENTS ON 2005 NATIONAL ELECTRICAL CODE® REPORT ON PROPOSALS
INSTRUCTIONS — PLEASE READ CAREFULLY Office Use Only Type or print legibly in black ink. Use a separate copy for each comment. Limit each comment to a SINGLE section. All comments must be received by NFPA by 5 p.m., EDST, Friday, October 31, 2003, to be considered for the 2005 National Electrical Code. Comments received after 5:00 p.m., EDST, Friday, October 31, 2003, will be returned to the submitter. If supplementary material (photographs, diagrams, reports, etc.) is included, you may be LOG # required to submit sufficient copies for all members and alternates of the technical committee. Date Rec'd: Please indicate in which format you wish to receive your ROP/ROC  electronic  paper  download (Note: In choosing the download option, you intend to view the ROP/ROC from our Website; no copy will be sent to you.)
Date Name Tel. No.
Company
Street Address City State Zip
Please Indicate Organization Represented (if any)
1. Section/Paragraph
2. Comment on Proposal No. (from ROP)
3. Comment recommends (check one):  new text  revised text  deleted text
4. Comment (include proposed new wording, or identification of wording to be deleted): 5. Statement of Problem and Substantiation for Comment: (Note: State the problem that will be resolved by your recommendation; give the specific reason for your comment including copies of tests, research papers, fire experience, etc. If more than 200 words, it may be abstracted for publication.) 6.  This Comment is original material. (Note: Original material is considered to be the submitter's own idea based on or as a result of his/her own experience, thought or research and, to the best of his/her knowledge, is not copied from another source.)  This Comment is not original material, its source (if known) is as follows: Note 1: Type or print legibly in black ink. Note 2: If supplementary material (photographs, diagrams, reports, etc.) is included, you may be required to submit sufficient copies for all members and alternates of the technical committee.
I hereby grant the NFPA all and full rights in copyright, in this proposal, and I understand that I acquire no rights in any publication of NFPA in which this proposal in this or another similar or analogous form is used.
Signature (Required)
Mail to: Secretary, Standards Council, National Fire Protection Association, 1 Batterymarch Park, P.O. Box 9101, Quincy, MA 02269 or FAX to 617-770-3500
[This message has been edited by Joe Tedesco (edited 02-26-2003).]
Joe, Isn't a little early for the comments? The ROP doesn't get mailed until July 11. Or will the panel action on the proposals be published onlne prior to the mailing date? Don
That may be true, and my reason for posting the form here is to begin training those who may want to support the efforts that will be accomplished by sending in a comment. I will keep the thread alive. PLEASE USE SEPARATE FORM FOR EACH PROPOSAL · · NFPA Fax: (617) 770-3500 Mail to: Secretary, Standards Council · · National Fire Protection Association 1 Batterymarch Park · · PO Box 9101 · · Quincy, MA 02269-9101 INSTRUCTIONS FOR SUBMITTING PROPOSALS ON NFPA TECHNICAL COMMITTEE DOCUMENTS Contact NFPA Codes and Standards Administration for final date for receipt of proposals on a specific document. Use a separate proposal form for submitting each proposed amendment. Note: All proposals must be received by 5:00 p.m. EST/EDST on the published proposal closing date. 1. Type or print legibly in black ink. 2. Indicate the number, edition year, and title of the document. Also indicate the specific section or paragraph that the proposed amendment applies to. 3. Check the appropriate box to indicate whether this proposal recommends adding new text, revising existing text, or deleting text. 4. In the space identified as “Proposal” indicate the exact wording you propose as new or revised text, or the text you propose to be deleted. 5. In the space titled “Statement of Problem and Substantiation for Proposal” state the problems that will be resolved by your recommendation and give the specific reason for your proposal. Include copies of test results, research papers, fire experience, or other materials that substantiate your recommendation. 6. Check the appropriate box to indicate whether or not this proposal is original material, and if it is not, indicate the source of the material. 7. Sign the proposal. If supplementary material (photographs, diagrams, reports, etc.) is included, you may be required to submit sufficient copies for all members and alternates of the technical committee. The technical committee is authorized to abstract the “Statement of Problem and Substantiation for Proposal” if it exceeds 200 words for publication in the Report on Proposals. NOTE: The NFPA Regulations Governing Committee Projects in Paragraph 4-3.3 states: Each proposal shall be submitted to the Council Secretary and shall include the following: (a) Identification of the submitter and his or her affiliation (i.e. technical committee, organization, company), where appropriate (b) Identification of the document, edition of the document, and paragraph of the document to which the proposal is directed (c) Proposed text of the proposal, including the wording to be added, revised (and how revised), or deleted (d) Statement of the problem and substantiation for proposal (e) Signature of the submitter (f) Two copies of any document(s) (other than an NFPA document) being proposed as a reference standard or publication (see 3-3.7) [This message has been edited by Joe Tedesco (edited 02-26-2003).]
