Well, do you have info about how the 3' rule was established (for "securely fastening" EMT, and PVC, and "securing" RMC)? My code book library is missing 65 and 68, and somewhere in there the EMT rule came into play (I certainly didn't see it in the 59 or 62 BFU standards). A question in another thread prompted this bit of curiosity.
I was thinking that they might have come up with 3' because it would be a stiff enough attachment to take some normal amount of abuse and bending without pulling out of the connector enough to lose an equipment ground path, but then again, that doesn't make sense if the same measurement is used for PVC and RMC. Does your info get that detailed?
While I'm on the subject, do you know if the BFU standards were ever considered an adopted legal document, such that it would possibly be included in some older, long established, law libraries?
Added during editing...
Forgot to mention: I DO have the electronic downloads of ROP's and ROC's, for the past two cycles (and without having membership, though I suppose that is changing by now).
[This message has been edited by Elzappr (edited 02-24-2003).]
