1 members (Scott35), 524 guests, and 23 robots.
#83467 02/03/03 02:41 PM
mborner Offline OP
Is there a NEC code that requires conduit runs with fiber to have junction boxes at every 100ft intervals.
Thanks for your help
#83468 02/03/03 05:07 PM
No, there are no code rules about the distance between junction boxes or pull points. The only code rule is that you cannot exceed 360° of bend between pull points. The fiber run has to be designed to limit the pulling stress on the fiber, however, excessive pull points increase the chance that the fiber will be damaged when it is installed.
don
#83469 02/04/03 08:16 PM
Ron Offline
I think there are installation standards from TIA/EIA and BICSI regarding pull points.
Ron
