0 members (), 433 guests, and 18 robots.
#83397 01/30/03 03:19 PM
Hmmm...Hubbell lists their 3/4 T condulets at only 7 cu.in.
Donnie
#83398 01/30/03 03:31 PM
I haven't checked this particular installation yet, but in their other conduit runs, they are using 1 1/4 condulets with RE bushings. The OZ 1 1/4 T condulet is listed at 32 cu. in.
ML
#83399 01/30/03 04:50 PM
I didn't see anything in Bedford's Electrical Code that would limit the length of the flex.. http://livepublish.municode.com/17/lpext.dll?f=templates&fn=main-j.htm&vid=11924
Donnie
#83400 01/30/03 05:00 PM
txsparky,
Just to let you know, the work in question is happening at the DFW Airport. You aren't the electrical contractor are you??? [Linked Image]
By the way, I live in Bedford.....
ML
#83401 01/30/03 05:45 PM
I got the Bedford from your profile and just assumed the work was in that general area.The airport may have stricter codes from FAA.Not sure though.
I'm in Spring,just north of Houston,but I'll be in Plano tommorrow.
Donnie
#83402 01/30/03 05:51 PM
Why didn't they use j-boxes?
I believe using an oversized condulet poses problems of a different nature.
314.23? Exception?
#83403 01/30/03 06:35 PM
Redsy,I thought of the support issues with the oversize condulet but figured since the inspector didnt cite it,to let it go.
Donnie
