0 members (), 433 guests, and 18 robots.
#82301 11/04/02 07:40 AM
sparky Offline OP
I'm about to wire a small woodshop, a retiree is making cabinetry, etc. The place will be open, no sheetrock.
I am questioning wheather to use pvc drops ,pvc boxes,pvc covers or emt drops and w/p boxes & covers here.
any advice appreciated, thanx
~Steve
I would go for the EMT over the PVC and you should consider enclosures that are dust tight.
Here we call them Plenum boxes. They have no holes in them and the covers have gasket material glued to one side.
sparky Offline OP
Plenum boxes
very interesting Pearlfish...... slang aside, is there a proper 'parts' name for these ?
I've found that PVC boxes and especially the covers are prohibitively expensive for anything but the most understanding agricultural work.
Yes, please more info on the plenum boxes!
[This message has been edited by sparky66wv (edited 11-04-2002).]
-Virgil
5 Star Inspections
Member IAEI
Sparkey, Appleton lists their 4" box as "4SPD Plenum Box" 2 1/8" deep, and the cover as "8465P Plenum box cover". If you need it in 4 11/16" they are "4SP-JD Plenum box" and "8487P cover".
sparky Offline OP
ok, i'm at the Appleton site, but i'm having trouble locating that exact #'s reference there.....
~PS,
it is my intention to run nm exposed @ 9' on rafters and 'pipe down' , barring any objections here
Steve, being an amature wood worker, I know in my shop (basement) I lean things up against every wall at times. I would lean towards the metal, and dust tight boxes.
Also, if by some chance you may be asked to run the dust collection pipes, there is some concern over static started fires in PVC systems.
If you are asked, let me know and I will try to find an article for you.
Roger
...static started fires in PVC systems.
More please!
*fears litigation from future fires from statically charged PVC installations*
-Virgil
5 Star Inspections
Member IAEI
Sparky66, this is not the article I was talking about, but I'm at work and don't have it here. This is one I came across on a forum a while back though. http://www.forums.woodnet.net/ubb/Forum2/HTML/000418.html
Roger
