Mixing of cables over 600 volts and cables under 600 volts in manholes is permitted by Art. 300-3(2)(e) if they are "effectively separated". "Effectively separated" is not defined. So far, I have not seen anything in IEEE or other publication to give definition. Some say that Art. 725-54 implies the Code Panel requires cable separation in accordance with the Exceptions.
Some thoughts from this forum??
