1 members (Scott35), 553 guests, and 32 robots.
#77020 04/13/01 10:10 AM
1)> I AM INSTALLING A SEMI INGROUND POOL THAT I NEED TO BOND I UNDERSTAND U RUN A #8 WIRE TO ALL METAL PARTS BUT WHERE DOES THIS WIRE HOOK UP TOO ONCE YOU CONNECTED IT TO THE METAL PARTS?
#77021 04/13/01 10:59 AM
It is not required to connect to anything else. That is why the section (680-22) is called "bonding" and not "grounding". The purpose is to make sure that every conductive object at the pool is at the same voltage.
#77022 04/13/01 12:05 PM
BKLYNN,
Hello to a fellow New Yorker!
Also connect to the following items if they exist:
  • Groung Lug on the pump
  • Ladder (unless totally plastic)
  • other metal objects within 5 feet such as Chain link fence, metal framed windows, doors, leaders and gutters.
Bill (LI, NY)
#77023 04/13/01 01:27 PM
BILL ARE YOU IN SUFFOLK? WHAT DO U THINK OF POOL LIGHTS THAT HOOK UP THROUGH THE FILTER RETURN?
#77024 04/13/01 04:08 PM
BKLYNN,
Yes, I'm in Suffolk. (Centereach)
I'm not sure what you mean. I'm not familiar with anything like that.
I've seen some plug-in types of lights is that what you mean?
