0 members (), 408 guests, and 18 robots.
Page 3 of 3 1 2 3
#75369 02/26/07 02:34 PM
I just looked at some Christmas 2006 approved rope light. The difference is the actuall connection to the rope is a molded connector. It had a threaded end with male and female pins. These are 25' strings, packaged 2 in a box and I paid $6 for it. The only difference between this and the original product is you can't take the connectors off the rope. A very simple and safe answer to the "cutting" issue would be a glued on, permanent cap for the cut end. Perhaps the manufacturer would do that and seek the listing if the demand was there
#75370 02/26/07 02:44 PM
ITO, compared to the regular store price, this guy isn't all that cheap. You can buy a 50' box, (2 strands of 25') with 2 power cords for 10-15 bucks. 150 feet is less than he charges with an extra power cord to boot.
#75371 02/26/07 07:20 PM
I checked into ITO's link.....hmmmm
Reading thru, seems that the mfg is hinting that it can be cut every 24" marked increment; but they also state that they don't condone, reccomend, etc., cutting. Something to the effect of 'cut at your own risk'. No cutting instructions supplied! 'Use common sense'; '40 year old design' etc.
Snip, seperate, insulate, seal ??
Last job I saw rope on, I had to tell the EC that the tag states 'do not coil excess'.
Page 3 of 3 1 2 3
