1 members (Scott35), 510 guests, and 37 robots.
#66485 06/05/06 03:32 PM
mshaw Offline OP
I have been asked to bid a job to evaluate the condition of the aluminum wiring in two multi tenant apartment buildings. My first gut instinct is to say no due to the liability issues. Is there a proper way to go about this evaluation. One fellow electrician said you have to remove every device and check the connections and torque on eack screw/lug ect.
Ideas? HELP!
#66486 06/05/06 06:17 PM
I have a 'rule'....
Go by my first feeling!
#66487 06/05/06 07:32 PM
Bid it at T&M, in phases if they want..
CYA, Mike..
#66488 06/05/06 07:44 PM
Not only do you have to check each device, but you are going to have to make sure each and every device is compatible with aluminum.
I went through this last year and ended up having to put a copper jumper between each aluminum conductor and the device terminals using wire connectors with a CU/AL rating. My supplier doesn't carry any devices that are rated for AL but was able to get me the CU/AL wire connectors. I did this job at T&M.
Sixer
#66489 06/09/06 10:05 PM
#66490 06/10/06 11:22 AM
I saw in a new house being built, they used aluminum wiring for a 50a 240v circuit. Is this still used in the larger size wire? Is it legal? I know it for range cable, feeders etc., a long time after the 70's when they used the aluminum #12 general lighting circuits for homes.
