1 members (Scott35), 571 guests, and 39 robots.
#65793 05/12/06 11:22 PM
BigB Offline OP
It's getting pretty hot here in the desert and I have been getting a LOT of attic work. I was thinking of buying a cooling vest. Do any of you have any experience with these? The pricing varies a lot on the different brands, but StaCool claims to be the best.
#65794 05/13/06 12:46 AM
Used them on the bike and they worked good. The pricey ones worked the best but for attic work I think I would get a cheep one first because the dirt may be a problem. Let us know how it works out for you. Rod
#65795 05/14/06 09:21 PM
BigB Offline OP
Did you have the kind with the cold packs or the kind you soak in water?
#65796 05/15/06 02:47 PM
I've used the kind you soak in water. Has to be dry out, these probably don't work in the midwest. They worked pretty well, kept the body temp down.
A better idea may be to see if you can do your attic work at 5-8 in the morning. I know of a few HVAC companies that do this, and the early riser customers don't mind it a bit. Actually, they like it because they don't have to take time off work to let the guys in.
