507
40
Why do they make fuse rejectors for 30 amp plug fuses, when a 30 amp plug fuse is the biggest they make? I thought the rejectors were so you couldn't increase the size of the fuse, but maybe I'm missing something here?
Sixer
They reject different fuse types as well.
Define the term "rejector"?.
I was wondering what you meant when you said a " 30 amp rejector"! I have never really seen those " Type S" fuses around here... The only one I think I have actually seen was at my old work in the fuse isle buried under a mound of dust! The " Rejectors" I know of were plastic rings of either the 15 or 20 amp version that you screwed into your panel with a special fiber tool...The 15's would only allow a 15A fuse in but the 20A rejectors would allow a 15 or 20A fuse to be inserted... They worked but I sometimes had problems with them when using some brands of type "D" fuse of the correct rating, the rejectors rejected them too!
Rewire, I know of the rejectors you are talking about, but those are different. I haven't seen those in years. The ones I'm talking about take the type S fuses that Iwire has linked to. This is the only picture I could find of the adaptor: http://www.hvactool.com/product_images/MA-16SA.gif The little wire sticking out the side of the threads make it tamper resistant. My reason for this post is lately we've been installing a lot of these rejectors (adaptors) and type S fuses to satisfy the insurance companies requirements. I couldn't figure out why they even made one for 30 amps, but e57 answered my question (duh...I never even thought of that!)....thanks.
Sixer
They used to make a 35 amp edison base fuse.
Posts: 9,931 Likes: 34
The S adapter also rejects pennies, gum wrappers and aluminum foil ... even the 30. The 30a adapter will take a 20 (same thread size) but the 20 won't take a 30. There is a shoulder on the 30a fuse that keeps it from fitting in a 20a adapter.
Anybody can help to let me know from where I can buy fuse rejectors, I asked different supplier, nobody carry it
Posts: 7,382 Likes: 7
Go to Bussmann.com or Littlefuse website, customer service, and ask for a supplier in your area.
